Forums >> Revit Building >> Technical Support >> Openings ??
Thu, May 4, 2006 at 5:57:10 PM | Openings ??
Andrew1
Im sure I cant do this but I'll ask .... can I change the cut angle of an opening?? (e.g make it cut a 25d or 45d etc) cheers again andrew Post edited on 2006-05-04 17:57:48
Thu, May 4, 2006 at 8:20:34 PM | RE: Openings ??
eldados
eldados Avatar
4.5 Stars: 8 Votes
don't think you can, but i would use voids...
Integrator
KarelCAD
Thu, May 4, 2006 at 11:32:07 PM | RE: Openings ??
Andrew1
Cheers, Voids look interesting! And is possibly what I need; is this what you would use to create as slab thicking?? I’m trying to create a complex slab with thicking’s of different depths and I’m currently joining slabs above one another the create the step, but need chamfers (angles) for the transition. Looks like I can uses one slab thickness and remove voids to suit? hmmm now just have to work out how to use them !!
Copy Monitor Shaft Openings
Thu, Oct 21, 2010 at 8:16:14 PM
Curved wall openings
Fri, Oct 15, 2010 at 12:42:11 AM
Openings in different phases
Tue, Apr 20, 2021 at 7:23:42 PM
Openings--how do you control constraints?
Thu, Jun 11, 2009 at 1:57:49 PM
face based shapes with openings
Mon, Mar 9, 2009 at 3:10:10 PM
Page generation time: 0.0324
