Forums >> Revit Building >> Technical Support >> Section tags
Thu, May 4, 2006 at 9:36:25 AM | Section tags
ackerun
Is there any way to change the size of the text on the section tags without changing the overall scale?
Thu, May 4, 2006 at 10:27:37 AM | RE: Section tags
fazerneil
4 Stars: 5 Votes
Open up a section tag family, save it as new and then edit all you want, then load it into your projects.
section tags for broken wall sections
Fri, Dec 7, 2007 at 10:57:25 AM
Section Tags missing (again)
Wed, Aug 26, 2009 at 10:50:38 AM
Floating Section Tags
Mon, Nov 26, 2007 at 1:09:03 PM
room tags in section
Wed, Jan 10, 2007 at 11:22:58 AM
Elevation Tags not showing when I cut a Section View
Mon, Oct 20, 2014 at 2:43:05 PM
Page generation time: 4.7347
