16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Curtain wall mullions
I have put a curtain wall in a project but there are no mullions loaded into the project. I can’t figured out where to load the mullions from. Are there mullions in the metric folder?
Any help would be greatly appreciated.
Thanks
Macca Sunshine Coast QLD Australia |
Okay, this is a little confusing...
Mullions are System families which always reside within the project, however these system families can also use profiles that you load in.
Its sounds as though you have most likely purged out all the mullions... They are still in the project its just that all their types have been removed.
You have two options:
1. Use transfer project standards from a clean template and copy curtain wall mullions OR
2. In your project browser scroll down to the families section, expand curtain wall mullions, right click each required mullion family and select new type, then set it as required.
HTH.
Thanks for your help Mr Spot. just feel like kicking yourself when something so simply can seem so hard.
Cheers
PS If I still lived in Brisbane I would have definately applied for the position at your firm.
3 Posts No Rating |
Shouldn't a corner mullion have been loaded from transfering project standards? All I got was the 2.5"x5". I tried creating a corner mullion and it won't let me check the box in the parameters box. Any help is welcome and thank you.
Curtain wall with splayed mullions |
Tue, May 10, 2016 at 2:05:31 PM
Miter Curtain Wall Border Mullions |
Wed, Apr 21, 2010 at 3:04:57 PM
Angled and Straight Curtain Wall Mullions |
Mon, Feb 27, 2012 at 12:19:11 PM
Curtain wall and mullion issues |
Wed, Sep 5, 2007 at 7:38:14 PM
CURTAIN WALL MULLIONS |
Wed, Mar 29, 2006 at 3:39:13 PM
