Forums >> Revit Building >> Technical Support >> Autodesk issues Tech Bulletin: Service Issues Affecting Revit 9-Based Software
Mon, May 1, 2006 at 11:02:48 PM | Autodesk issues Tech Bulletin: Service Issues Affecting Revit 9-Based Software
jobcaptain
jobcaptain Avatar
1 Stars: 2 Votes
Before you install any of your Revit 9-based software please read. Autodesk has discovered service issues that affect Autodesk Revit Building 9, Autodesk AutoCAD Revit Series--Building 9, Autodesk Revit Structure 3, and Autodesk AutoCAD Revit Series--Structure 3 software products. A conflict within Revit-based files utilizing Links has been found to impact overall application performance. In addition, an issue within cascading network licensing for the AutoCAD Revit Series products was discovered when only the Revit-based product was installed from the Series bundle--a condition found to prevent license access. To correct these service issues, Autodesk has created new builds containing corrections for each software product and will be available for download midweek. To download the new builds that are schedule to be available by end of business on Wednesday, Wednesday, May 3, 2006 are specified here for all affected products. http://taylor-tech.com/press/getReleaseById/383/story.html
LinkedIn Profile:
  • http://www.linkedin.com/in/danielhughes1/
I author Bradley BIM Blog: http://bradleybim.com
Virus software
Thu, Apr 26, 2012 at 5:27:21 PM
construction bulletin method?
Thu, Feb 5, 2009 at 4:12:34 PM
Revit 8.1 Service Pack
Mon, Oct 10, 2005 at 7:49:43 AM
Fill Patterns
Mon, May 4, 2015 at 12:45:08 PM
Service pack for Revit 2010
Sat, Jun 27, 2009 at 7:13:14 AM
Page generation time: 2.1565
