17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> View Planes
208 Posts No Rating |
Hi all,
This is driving me nuts!!
I have set my view range within my first floor plan to show a number of sweeps I have created (paving edge profiles). These profiles consist of a horizontal element and a vertical element directly below. Within the first floor plan, only the extremities of the horizontal element are show indicating the paving edge. This is what I am after.
When apllying the same view range settings to my ground floor plan to show the paving edges at this level, I can see lines indicating the vertical part of the paving edge sweep, as if the horizontal element is transparant. It is the same profile as was used in the first floor plan.
I have tried every concievable combination of view range settings.
What could be causing this?
cadjockey
Hi all,
Some further points.
The paving edge is set slightly higher (35mm and called FFL) than the ground floor level which is the associated level.
When applying the view range settings within the FFL level the paving edge shows correctly however, I was under the impression that I could offset the 'Bottom' setting by the required amount from the associated level 'Gound level'.
cadjockey
Wish List - Toggle Reference Planes |
Fri, Sep 24, 2010 at 1:23:59 PM
Hidden Reference Planes disappeared |
Fri, Jun 30, 2017 at 11:50:56 AM
VIEW PORT ALIGNING WITH REF PLANES NOT WORKING |
Tue, Jan 3, 2017 at 1:59:27 PM
Replacing levels with ref planes or deleting excess levels |
Thu, Apr 17, 2008 at 11:10:37 AM
reference planes |
Wed, May 24, 2006 at 10:19:12 AM
