Forums >> Revit Building >> Technical Support >> fine detail missing on duplicated wall, plan view??
Mon, May 1, 2006 at 8:31:20 PM | fine detail missing on duplicated wall, plan view??
ICON
5 Stars: 3 Votes
duplicated an 8" conc. wall to add 1" rigid insulation for new wall style. when in "fine" detail level I don't see the different materials. I added the 1" thickness,I applied pattern to drafting view for rigid insulation, gave the materials thickness, adjusted view range and still only see a "course detail" view even when I select "fine detail" level. Anyone now why the detail doesn't show up in fine detail level. The wall does measure 9" so I know it's there, just can't see it. thank you randy
Make Walls Grey and Transparent in Plan view 'Fine Detail'
Thu, Nov 3, 2011 at 7:30:56 AM
Duplicated view - perset
Fri, Jun 15, 2007 at 10:49:53 AM
Detail Lines missing from view when placed on sheet
Sun, Jan 29, 2017 at 7:16:45 AM
Embedded Detail Shows in plan view, but not in the plan detail call out!
Fri, Mar 4, 2011 at 1:37:23 PM
Objects not showing in "fine" detail level
Tue, Mar 3, 2009 at 10:42:15 AM
Page generation time: 1.4286
