Forums >> Revit Building >> Technical Support >> Displaying windows above cut plane
Mon, May 1, 2006 at 1:54:03 PM | Displaying windows above cut plane
jframe
I have some clerestory windows that are above the cut plane in a plan view that will not display, how do I get them to show?
Jeff Frame AIA
Mon, May 1, 2006 at 2:33:44 PM | RE: Displaying windows above cut plane
TomDorner
4.5 Stars: 25 Votes
This is what "plan regions" are for. You can find them on the View Tab
Mon, May 1, 2006 at 3:41:25 PM | RE: Displaying windows above cut plane
coreed
coreed Avatar
4 Stars: 16 Votes
take a look at this thread http://www.revitcity.com/forums.php?action=viewthread&thread_id=3776 HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jul 26, 2006 at 9:54:53 PM | RE: Displaying windows above cut plane
jhudtwalcker
jhudtwalcker Avatar
and what if I need the lines of the window set to dashed? In my country, all objects above cut plane are drawn with dashed lines
Thu, Jul 27, 2006 at 10:38:42 AM | RE: Displaying windows above cut plane
TomDorner
4.5 Stars: 25 Votes
Probably the easiest thing to do is use the "linework tool" to change the display of the lines to dashed. The "linework" tool is the icon that looks like an old fashioned fountain pen. It allows you line by line graphic over-ride of any line in an object. If you use it set to dashed lines an touch all the lines you want to change the display of it should work for you. Remember, this is only changing the display of "lines" not actually adding any lines. You can also set things to be invisible or any other line style. If you want to get things back the way they norammaly display, set the linework tool to "by category". HTH Tom Post edited on 2006-07-27 10:39:17
Fri, Jan 27, 2012 at 7:07:49 PM | Displaying windows above cut plane
Melva
Thanks for the info!
Mon, Nov 4, 2013 at 8:43:42 AM | Displaying windows above cut plane
oliverpeter
Kinda tricky but that is how it is, in fact it is not user friendly
Mon, Nov 4, 2013 at 9:11:38 AM | Displaying windows above cut plane
I don't know what your needs are but in addition to the linework tool, you also have over-ride graphics by element where an entire element can be set to a different lineweight and line type.  You can also use filters to do this.
Tue, Sep 9, 2014 at 9:17:50 PM | Displaying windows above cut plane
youaremybaby2008
Hi jframe ! I recently solve it by using "line work" tool and "plan region"! You can check my video at this link:
https://www.youtube.com/watch?v=fbLM6DqKnRw
Sun, Oct 26, 2014 at 3:28:10 AM | Displaying windows above cut plane
ryanroven
Here http://www.revitcity.com/forums.php?action=viewthread&thread_id=15200 check it, it is actually about clerestory windows in cut plane for plan regions. There are also several guide about it, check the entire forum.
-interior door maker at http://caldwells.com/interior-doors
Mon, Oct 27, 2014 at 2:39:24 AM | Displaying windows above cut plane
#11
leahdudu
Actually u need to modify the (view range ) in properitites of floor plan
modify the Cut plane value then u'll see the window.
high windows and cut plane
Mon, Mar 19, 2012 at 10:15:29 AM
Cut Plane
Wed, Nov 19, 2008 at 7:03:50 PM
Showing High Windows Cut In Plan
Mon, May 28, 2007 at 3:09:47 PM
Very basic question about displaying lines
Mon, Apr 28, 2008 at 11:35:53 AM
Cut plane for doors and widows different from plan!!
Wed, Oct 18, 2006 at 8:41:37 AM
Page generation time: 0.8001
