Forums >> Revit Building >> Technical Support >> Is it possible to change the lineweight of text in a dimension?
Mon, May 1, 2006 at 9:29:29 AM | Is it possible to change the lineweight of text in a dimension?
psubenhess
I must be missing something obvious or else it's just not possbile to do it. Any help would be greatly appreciated. Thanks in advance.
Mon, May 1, 2006 at 10:34:22 AM | RE: Is it possible to change the lineweight of text in a dimension?
TomDorner
4.5 Stars: 25 Votes
The "line weight" is a type parameter of the dimension style. Select dimensionstyle and go the the type properties to change.
Mon, May 1, 2006 at 10:44:09 AM | RE: Is it possible to change the lineweight of text in a dimension?
psubenhess
Thanks for the reply. I am working on Revit 8 (Building) and there is no type parameter for the lineweight of the TEXT in the dimension. There is a type parameter for the lineweight of the dimension line, tick mark, etc. but nothing for the lineweight of the dimension text.
Mon, May 1, 2006 at 11:11:08 AM | RE: Is it possible to change the lineweight of text in a dimension?
TomDorner
4.5 Stars: 25 Votes
Revit uses Windows TTF's. How do you control their lineweight in Excel, Word, Photoshop, Access...............??
Wed, Apr 16, 2008 at 7:40:40 PM | Is it possible to change the lineweight of text in a dimension?
metacarpus
Maybe let me ask the question this way.....how would I bold the text in a dimension?
Wed, Apr 16, 2008 at 11:53:42 PM | Is it possible to change the lineweight of text in a dimension?
chiragpklg
4 Stars: 11 Votes
u can't bold the text in the dimension but u can rather increase the text size from the dimension properties in the Text Parameters.
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Is it possible to change the lineweight of dimension text?
Wed, May 10, 2006 at 4:53:23 PM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Dimension Text Overide
Wed, Jun 27, 2007 at 7:13:42 PM
cHANGE DIMENSION TEXT
Thu, Aug 2, 2018 at 1:49:44 PM
Why I cant change Dimension fonts?
Thu, Aug 10, 2017 at 11:51:39 AM
Page generation time: 0.4834
