Forums >> Revit Building >> Technical Support >> Viewports
Mon, May 1, 2006 at 7:11:04 AM | Viewports
bigroo
Is it possible to resize the viewport windows that are put on sheets or are they fixed sizes?
Mon, May 1, 2006 at 7:40:57 AM | RE: Viewports
jOOc
You can change view scale under properties. eg. From 1:100 to 1:50 to make it bigger or 1:100 to 1:200 to make it smaller.
Mon, May 1, 2006 at 8:38:58 AM | RE: Viewports
bolandereric
The view ports are deterimined by what is on the page that you pulled on. Also if you right click on your drawing and go to veiw properties and in the extents file you can check the box that syas Crop Region when you go out of the properties box thier will be a box around your drawing and you can move the crop region just by clicking on it and draging the nodes. what ever shows up in the drawing is what will show up on the sheet when you pull it on to the sheet.
Edit Visibility Graphics in multiple viewports?
Mon, Nov 28, 2011 at 1:37:05 PM
Viewports orginizing on sheet
Mon, Apr 18, 2016 at 10:45:14 AM
Room Plans, Non Rectangular viewports from Revit 2014 and Python Shell
Thu, May 23, 2013 at 2:28:19 PM
many viewports
Mon, Aug 24, 2009 at 9:17:12 AM
Revit FBX to 3D Max 2011 causes black or unresponsive viewports
Fri, Jan 13, 2012 at 11:29:51 AM
Page generation time: 1.9581
