Forums >> Revit Building >> Technical Support >> Skylights and oblique objects
Tue, Aug 10, 2004 at 10:05:46 AM | Skylights and oblique objects
mikefields27
I have found one insumountable problem in Revit. When I cut through a [e.g.] skylight in plan [or sectionally from the front]. it gives me the entire unit projecting above my cutplane. I suppose it does not understand it as a plan element so for the time being I am patching over it, but this is, of course, an imperfect solution.
Similarly, in a tall roof that I cut through [plan again], I do not wish to see the whole roof below, but it appears bpast my view depth.
Has anyone else run into these issues with oblique objects, and do you have any suggestions?
Thanks.
Wed, Aug 11, 2004 at 8:46:55 AM | RE: Skylights and oblique objects
mikefields27
I rescend my " [or sectionally from the front] " from the described of the problem above.
The sections are smart enough.
How do I make the plan this smart?
Oblique Symbolic lines
Thu, Jan 1, 2015 at 3:47:42 PM
window schedule - skylights
Wed, Jun 7, 2006 at 10:00:02 AM
Adding skylights and slopes to a roof
Thu, Jul 12, 2012 at 8:33:07 AM
Skylights and Ceilings
Thu, Jul 9, 2009 at 5:01:30 PM
Wall/Roof Attachment Phasing Issue
Wed, Aug 27, 2008 at 2:34:16 PM
Page generation time: 0.9859
