Forums >> Revit Building >> Technical Support >> mitering gutters
Sun, Apr 30, 2006 at 9:50:45 AM | mitering gutters
ICON
5 Stars: 3 Votes
Any logic behind my gutters not automaitcally mitering in some cases and mitering in others. I'm pretty sure that my verticle offsets were the same and I've tried "adding" gutter and "starting new" gutter, haven't seen any difference in end result. Randy Post edited on 2006-04-30 09:53:05 Post edited on 2006-04-30 09:53:28 Post edited on 2006-04-30 13:16:36
Tue, May 2, 2006 at 6:14:54 AM | RE: mitering gutters
SteveB
3.5 Stars: 5 Votes
they have to be aligned in elevation or section views. Use the align tool. Also you can stretch their ends by picking and the gutter, finding the endpoint and stretching it to make sure the gutters actually touch.
Tue, May 2, 2006 at 7:10:01 AM | RE: mitering gutters
ICON
5 Stars: 3 Votes
thank you. I'll check that out. Randy
Tue, May 2, 2006 at 7:49:25 AM | RE: mitering gutters
latemore
latemore Avatar
3 Stars: 2 Votes
not sure if this would help, but karelcad in brisbane showed us a trick whereby you use a fascia sweep, whether it is a gutter profile, or a combination gutter/fascia. fascia sweeps for some reason tend to mitre better at corners. well they do for me anyway!
Tue, May 2, 2006 at 8:59:03 AM | RE: mitering gutters
ICON
5 Stars: 3 Votes
Thank you
Gutters
Mon, Jun 5, 2006 at 2:08:11 AM
Gutters and downspouts
Sat, May 20, 2017 at 9:12:09 AM
connecting gutters
Thu, Sep 12, 2013 at 2:45:24 PM
creating gutters
Mon, Jun 5, 2006 at 7:25:06 AM
Tagging Gutters, Fascias, Sweeps, Reveals & Such (2010)
Fri, Jan 29, 2010 at 12:58:01 AM
Page generation time: 2.2055
