Forums >> General Discussion >> Revit Project Management >> Arc window.
Fri, Oct 21, 2016 at 7:32:51 AM | Arc window.
lukdab
Hi.
I need to create an arc window family in which I can edit HEIGHT of the arc in type.
Or curtain wall window that would fit to curtain wall with arc.
Any idea?
Fri, Oct 21, 2016 at 9:27:45 AM | Arc window.
You can create this in the family.  Have you ever done one?  The radius of the top can be a parameter and the location of the center can be contolled with a parameter as well.
Fri, Oct 21, 2016 at 1:57:31 PM | Arc window.
sllana
5 Stars: 2 Votes
...or you can make a curtain wall, edit its profile as an arc and thats it. But if mulliosn are radial, must be a window family.
Mon, Oct 24, 2016 at 2:06:50 AM | Arc window.
lukdab
WWHub.
I know that but I have lot of diffirent existing windows and all of them have similiar height of arc. So it would be way easier to control only the height.
Silana.
I have curtain walls with their profiles edited. Now I want to place a windows instead of glass panels. The family I have doesn't work with arc. But at the end the goal is to place a windows tags.
Mon, Oct 24, 2016 at 10:14:23 AM | Arc window.
We often use CW's for windows.  We created a wall tag that mimicks the window tag to tag these as a window.  Then we use a wall schedule for these "windows" that is set up just like the window schedule and placed immediately below the actual window schedule.
Divide arc by length
Fri, Sep 7, 2007 at 6:17:46 PM
Arc Lines display as straight lines
Sun, Jun 12, 2011 at 10:07:46 AM
ARC LEADER NO TEXT
Thu, May 2, 2013 at 10:36:04 AM
Arc Walls with curved top?
Thu, Aug 7, 2008 at 2:04:21 PM
Parametric Arc Sweeps - How to Bypass the Concentric Arc????
Mon, Jan 14, 2013 at 9:00:26 PM
Page generation time: 0.4436
