Forums >> Revit Building >> Technical Support >> section line not showing
Fri, Apr 28, 2006 at 11:09:22 AM | section line not showing
KCPH
this seems like a simple problem & i hope it is... i have sections cut through my project, but i cant see them on the first floor plan! * they are turned on in view properties - annotations * they are visible on the second floor plan * i can draw a new one and its visible * the sections views are still there and viewable (Section 1, Section2) why cant i get them to show on my first floor plan? JL
Fri, Apr 28, 2006 at 11:27:09 AM | RE: section line not showing
arch00
Is the section box stretched so that it covers shows the first floor? If the section does not cut through the ground floor it will not show up on the plan. Gar
Fri, Apr 28, 2006 at 12:04:34 PM | RE: section line not showing
gdoorn
1 Stars: 1 Votes
also try to drag your mouse over where they should be. you can hide certain annotation objects in specific views...you may have accidently hidden them. if they highlight, right-click on them, and click "show annotation in current view" Arch00's suggestion is good too. that happened with me and my grid lines two weeks ago.
Fri, Apr 28, 2006 at 12:18:09 PM | RE: section line not showing
KCPH
ive actually thought of both of those and neither apply... my section views show both floors... i cant mouse over them...kind of like the hidden level annotation in elevation views... JL
Fri, Apr 28, 2006 at 12:53:02 PM | RE: section line not showing
Thread Post Kudo! #5
TomDorner
4.5 Stars: 25 Votes
There are a couple of other possibilities: 1. Check the properties of the section line. There is a "hide at scale courser than" setting. If your fist floor plan view scale is 3/32" and the section line is set to hide at scales courser than 1/8" that is what will happen. 2. Check phasing 3. Check discipline. If your section is set to architectural and your view is set to structural or coordination your section won't show. HTH Tom
Fri, Apr 28, 2006 at 1:00:54 PM | RE: section line not showing
KCPH
thanks tomdinmn! that was it. the scale went from 1/4 to 3/16 during its evolution and i changed it back to 1/4 and there they were! i changed the properties to "hide at scale courser than" 3/16 and it looks great! wont let that one get me again! JL
Fri, Aug 7, 2015 at 12:06:45 PM | section line not showing
malavika
Thanks Tom Domer. I was struggling for a while to fix it !
Section line angled?
Sat, Jan 20, 2007 at 10:45:03 AM
Section line disappears from plan when section view is placed on same sheet
Thu, Sep 4, 2014 at 7:46:20 AM
Section line --goes up but not down
Mon, Jun 21, 2010 at 6:03:12 PM
Line Weights not showing in View
Tue, Jul 8, 2014 at 12:45:18 PM
Void extrusion not showing in section cut
Thu, Jun 12, 2014 at 12:36:06 PM
Page generation time: 3.1269
