Forums >> Revit Building >> Technical Support >> Missing windows in Elevation
Fri, Apr 28, 2006 at 3:49:35 AM | Missing windows in Elevation
jaimetektus
1 Stars: 1 Votes
Hi, I've made a window family and imported it into my working model and placed it in a wall. It is visible in 3D but when I switch to elevations it is missing. And when go to plan it is also missing, I dont think it has anything to do with the workplane as I have tried adjusting this but to no avail. Any help would be appreciated.
Fri, Apr 28, 2006 at 5:01:16 AM | RE: Missing windows in Elevation
jyothi
Hai, Have u edited the opening in the window family that you have created , check with that that might be one of the reason.i also had same problem then i realised it was due to the wall opening. let me know if this worked. Regards
Fri, Apr 28, 2006 at 7:45:29 AM | RE: Missing windows in Elevation
latemore
latemore Avatar
3 Stars: 2 Votes
just a beginners idea, but have you checked the visibility of your family elements, cos you can adjust how each view 'sees' elements.
Exterior Windows elevation
Sun, Aug 26, 2012 at 5:26:57 AM
12
Elements missing from elevation when behind a transparent tree
Tue, Jan 27, 2015 at 7:00:25 PM
front wall missing from my elevation
Wed, Sep 30, 2020 at 10:46:45 AM
Windows in elevation
Wed, Apr 25, 2007 at 5:05:33 AM
Section and interior elevation missing from file once it is linked
Tue, Jun 26, 2018 at 2:12:46 PM
Page generation time: 0.6723
