Forums >> Revit Building >> Technical Support >> FOUNDATIONS
Thu, Apr 27, 2006 at 10:02:30 AM | FOUNDATIONS
bryan324
HOW DO YOU DO A MONOLITHIC FOOTER AND A STEM WALL IN REVIT?
Thu, Apr 27, 2006 at 10:41:46 AM | RE: FOUNDATIONS
coreed
coreed Avatar
4 Stars: 16 Votes
i'm not familiar the phrase "stem wall" please explain
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Apr 27, 2006 at 10:52:25 AM | RE: FOUNDATIONS
bryan324
a stem wall if where you have a 24 or 36 inch footer and you have concrete blocks stacked on it to grade than you attatch your floor to it. its held together with morter and it has conc. poured down the center of it and it is reinforced with 2 pieces of vertical rebar. and do you know how to make a monolithic footer in revit??
Thu, Feb 21, 2008 at 2:06:42 PM | FOUNDATIONS
Arkane308
My best advice is to make a callout and edit the detail to your specifications.
Brick Corbelled Foundations
Mon, Aug 9, 2010 at 8:46:12 AM
foundations
Wed, May 14, 2008 at 1:13:53 PM
3D Views-Can you hide foundations/generic models underneath the topography?
Wed, Dec 6, 2006 at 2:04:04 PM
Revit 2024: Toposolids clash with walls/foundations...
Fri, May 31, 2024 at 6:31:39 PM
foundations reacting with columns
Thu, Oct 22, 2009 at 2:00:52 PM
Page generation time: 0.6828
