21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Creating roof
52 Posts No Rating |
Hai,
I need to create a roof which is a paraboliod shape,it has got to fixed point as slopes in two different direction. Please let me know if there are any metthod of creating it.
i am attaching the image and autocad file for details
Thanks,
Regards,
jyothi
hi,
This is the image for the roof,
can't see the image but you can either create 2 rooves and join, or have a look at my tutorial for complex slabs (it is creating rooves...)
25 Posts No Rating |
Where is the tutorial located?
"can't see the image but you can either create 2 rooves and join, or have a look at my tutorial for complex slabs (it is creating rooves...)"
That can be created using a simple blend. If you actually want to show the structure as well rather than a plane, i'd create a mass using a blend. Then use curtain system by face on the top of the mass and turn the mass off.
Creating Realistic Texture For Roof |
Tue, Feb 26, 2019 at 1:37:49 PM
Creating a roof that slopes with the walls |
Sun, Feb 27, 2011 at 2:35:54 PM
creating a joined wall roof system ? |
Mon, Apr 2, 2012 at 8:50:08 AM
Creating a Roof Plan in Revit |
Wed, Oct 3, 2007 at 8:51:58 AM
Roof design problems |
Fri, Jul 9, 2010 at 7:30:00 AM
12
