Forums >> Revit Building >> Technical Support >> Transfer User Materials
Wed, Apr 26, 2006 at 2:14:19 AM | Transfer User Materials
Steve1959
I am trying to do some work on a file on my second computor. The file is ok but the user materials that I created are not there. I created some new Pantone wall colors and saved them in the user materials file but thy dont appear on the second computer. I cant find a separate storage area for them, I presume they are project based only. If this is so why dont they transfer with the project file. With thanks Stev
Wed, Apr 26, 2006 at 8:48:34 AM | RE: Transfer User Materials
TomDorner
4.5 Stars: 25 Votes
Your "user" material library is not project based but rather works for all Revit projects. The path to find it is: C:Documents and SettingsAll UsersApplication DataAutodeskRevit Building 9RenderingAccuRenderRedist The file name is user.mlb You could copy it from the first computer to the second, but I would establish a more nuetral location for my user created material library and patterns and name it so it is unique to yourself. If you want to have the same version on two PC's, then choose a common network location, or if they are not networked you will manually have to copy the file around tracking which is the most current version. Be sure to add the new .mlb library path to the Revit Rendering location tab. HTH Tom Post edited on 2006-04-26 08:49:39
User Material file Location in Vista
Wed, Sep 23, 2009 at 11:23:50 PM
Transfer network materials
Tue, Apr 19, 2011 at 1:07:46 AM
Where are user materials stoered?
Wed, Jul 20, 2005 at 2:40:02 PM
New revit User Wanting To Create Materials Lib
Sat, Jan 20, 2007 at 9:57:48 AM
Default Materials? Transfer Materials?
Thu, Jan 18, 2007 at 10:45:12 PM
Page generation time: 0.1967
