Forums >> Revit Building >> Technical Support >> Sidelight Constraint
Tue, Apr 25, 2006 at 6:50:55 PM | Sidelight Constraint
Steve1959
Not sure if this is a difficult one but I cant seem to get a reply. I am unable to find a way to offset my entry door sidelights. Entry doors move ok but I cant align the sidelights. Please help!! Thanks in advance Steve
Thu, Apr 27, 2006 at 11:10:54 PM | RE: Sidelight Constraint
eldados
eldados Avatar
4.5 Stars: 8 Votes
go into your family and make sure the side lights are constrainted and locked to the bottom of your door that way it should move with the door, if you want to move them seperatly you will need to put a reference plane, put a dimension with a parameter and lock your sidelights bottom to the reference plane. is it clear enough?
Integrator
KarelCAD
Fri, Apr 28, 2006 at 3:09:47 AM | RE: Sidelight Constraint
Steve1959
Thanks Eldados. Sounds ok. Sidelights are separate to the door. Will try the dimension and parameter. Regards Steve Ballina NSW Australia (nearly as much sun)
Door Sidelight Constraint
Mon, Apr 24, 2006 at 12:56:28 AM
Door with on/off sidelight visibility
Thu, May 26, 2011 at 2:38:03 PM
Door with Sidelight - Instance parameters
Tue, Jul 27, 2010 at 4:09:31 PM
Laundry door & sidelight?
Mon, Dec 11, 2006 at 7:34:32 PM
Keep getting constraint error in "Nested & Arrayed Families by: Mr. Spot" tutori
Wed, Dec 8, 2004 at 3:13:13 PM
Page generation time: 0.2288
