Forums >> Revit Building >> Technical Support >> Railing Path Modification
Thu, Oct 20, 2016 at 11:00:57 AM | Railing Path Modification
kellyd94
Hello all,
I am using '15 and I am having an issue with my stair railings (weird, huh?). I think it should be a quick fix, but I can't seem to figure out how to do it. Basically I have a stair landing (a "catwalk" in this case) that is 4'-0" x 13'-6". I need to adjust the dimensions of said landing to 3'-6" x 13'-0". The landing adjusts correctly, but when I try to edit the railing path sketch, no matter what I do, I get the "The Railing line must be a single connected Sketch. If you want two separate pieces of Railing, create two or more separate Railings." I am not trying to add any railings, only move two existing ones. Any help would be greatly appreciated.
Thank you
Thu, Oct 20, 2016 at 11:27:38 AM | Railing Path Modification
You can 'stretch' railing lines to a new position but you don't want to erase and create new lines.
Railing issue
Wed, Jun 13, 2018 at 2:15:01 AM
Editing Top Rail Path on Landings
Thu, Apr 4, 2019 at 4:03:56 AM
Railing Extension Problem
Mon, Dec 5, 2016 at 12:52:29 PM
3D path insteads of 2D path
Mon, Mar 28, 2005 at 9:23:38 PM
Railings in Revit 2013
Sun, Jul 12, 2015 at 10:46:07 PM
Page generation time: 0.4470
