Forums >> Community >> The Studio >> plines in revit
Mon, Apr 24, 2006 at 9:13:04 PM | plines in revit
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
Is there any way to join lines like in autocad so I can offset them all at once. Thanks
Mon, Apr 24, 2006 at 11:48:25 PM | RE: plines in revit
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hover over a line and hit your tab key, this will select the string. You can also select lines between two points, by picking one line then hovering over the last line in the string you want and hit tab until you can select all lines in between them... This works for other elements also. Always use your tab key!! Smile
Splines to Polylines
Mon, Jul 7, 2008 at 7:27:59 AM
Export to DWG
Fri, Jan 13, 2006 at 6:13:15 PM
Jumpy Topo lines while edit or add Points
Mon, Aug 31, 2009 at 4:04:47 AM
Site Modeling
Mon, May 9, 2005 at 11:14:16 PM
Is this form possible to create in Revit?
Tue, Aug 26, 2014 at 12:01:04 PM
Page generation time: 2.3472
