Forums >> Revit Building >> Technical Support >> Creating circular sloped floors
Thu, Aug 5, 2004 at 10:20:20 AM | Creating circular sloped floors
hotrod67
Does anyone know how to create a sloped circular floor? I was able to make a floor using the line/circle option and split it, then slope it to the center. Only probelm is that when I mirror it to get the other side , how to you remove the middle line to make it one piece ?
Thu, Aug 5, 2004 at 6:06:06 PM | RE: Creating circular sloped floors
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If the floors are exactly aligned in the middle and of the same material, use the join geometry tool and the line should disappear.
Fri, Aug 6, 2004 at 3:32:30 PM | RE: Creating circular sloped floors
Steve_Stafford
5 Stars: 2 Votes
A circle sketch and a slope arrow would give you a solid circle floor that slopes too... Post edited on 2004-08-06 15:32:55
Circular Sloped Roof in Revit
Tue, Jul 19, 2016 at 9:43:06 AM
detail lines on sloped floors
Tue, Jan 24, 2012 at 4:00:04 PM
14
sloped floors
Thu, Jan 27, 2011 at 11:52:11 AM
Sloped railing on a Floor
Fri, Jul 2, 2010 at 11:32:10 AM
Mitering Sloped Floors?
Thu, Apr 1, 2010 at 6:14:41 AM
Page generation time: 0.3911
