Forums >> Revit Building >> Technical Support >> contours
Mon, Apr 24, 2006 at 2:55:05 AM | contours
Bhawani
Hi,please let me known how to do contours in easy method ,I have acad dwg only with elevations in meters and lines are in spline how can I take it to Revit and do the contouring.It is very very urgent. Thank u.
Mon, Apr 24, 2006 at 5:16:04 AM | RE: contours
jyothi
hai Bhawani, How are u? is ur contour plan in Autocad is in 3-D or only 2-D.? if its only in 2-D give each point the elevation and convert to 3-D in autocad, then import to Revit and go to site-- select topography---use imoprted-- select the layers which as got elevation it will automaticall create site for u. i am also creating a huge site using this method and it worked fimne. The other method is after importing Autocad dwg to revit u can give elevation to each point and say finish sketch. Bye let me know if it helped
Smoothing contours...
Tue, Feb 17, 2009 at 8:43:14 AM
New vs. Existing Contours [ 1 2 ]
Thu, Jun 28, 2012 at 2:27:20 PM
16
Topo surface Control from imported contours
Mon, Feb 17, 2014 at 7:28:49 AM
Changing the amount of contours between intervals.
Tue, Sep 20, 2011 at 3:00:40 PM
printing contours
Fri, Jul 30, 2010 at 2:19:00 PM
Page generation time: 0.3004
