Forums >> Revit Building >> Technical Support >> rendering walkthrought
Sun, Apr 23, 2006 at 11:44:27 PM | rendering walkthrought
fandi825
can somebody help me! I try to make rendering walkthrought with 300 frame as normal default setting. Is that rendering take long time to finish it, cause i try, it take me 3 days to finish. It's there others way to do it or I have to upgrade my pc or what can I do to make it more faster when rendering walkthrought.
Tue, Jul 25, 2006 at 10:26:04 AM | RE: rendering walkthrought
broncos4life
3.5 Stars: 11 Votes
I got a walkthrough to render in 2 hours, but I am running 2 gigs of ram and an AMD 3700 x64 Bit. What are the specs on your computer?
Tue, Jul 25, 2006 at 10:28:49 AM | RE: rendering walkthrought
rkitect
rkitect Avatar
4 Stars: 29 Votes
If you can stomach a hiddenline walkthrough, that will finish very quickly. Your other options are to render it in sections and edit it together using some video editing software. Some people will even render frames 1-100, then frames 101-200 and so on and then smoosh everything together using avi software. HTH and best of luck. _Carl
How to make trees/planting brighter in Walkthrought ???
Tue, Jan 4, 2011 at 6:10:58 PM
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:37 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:39 AM
22
09' Rendering Issue
Wed, Jun 3, 2009 at 4:22:51 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:50 PM
Page generation time: 0.1392
