Forums >> Revit Building >> Technical Support >> Solid Tool
Fri, Apr 21, 2006 at 10:23:16 PM | Solid Tool
Archstudio247
If you are using revit 8.0 does anyone know where the solid tool is to create solid forms or to be able to sweep a profile along a path? Is there even a solid tool, I am new to the program and have looked but can not find it.
Sat, Apr 22, 2006 at 2:58:10 AM | RE: Solid Tool
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
So you want to create an in-place family? A LITTLE FYI FIRST: IF ITS SOMETHING THAT IS GOING TO BE REPEATED THEN IT SHOULD BE AN EXTERNAL FAMILY. IN-PLACE FAMILIES THAT ARE REPEATED WILL HAVE BAD EFFECTS ON FILE SIZE. Also, what exactly are you looking to create. You can easily create host sweeps/reveals/fascia's gutters using a loaded profile. This tool is located in your modelling tab. For the custom geometry creation tools are only possible from within a family. To do an in-place familiy go to your modelling tab and hit the "create" button. Pick an appropriate family category then you'll see your solid/void tools that i think you're after. HTH.
Cannot add voids to a solid model
Fri, Oct 31, 2008 at 12:08:27 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
How to create a dome
Tue, Jan 6, 2009 at 12:02:25 PM
Solid Fill Hatch
Sun, Apr 1, 2007 at 8:56:31 PM
SF Inquiry tool like in Acad??
Wed, Jul 23, 2008 at 8:40:47 AM
Page generation time: 2.3418
