18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Curve Walls
6 Posts No Rating |
Can anybody help me out and explain to me how I can make a wall curve in a section view. If the wall I have is curved in plan, how can I make it curve in section also. So basically it would be curving in two different ways. Anyhelp would be much appreciated.
Do it as a sweep. Or if the curve in section changes do it as a blend between the top and bottom profiles. Best to use a mass then use wall by face in order to get your layers correct.
HTH.
4 Posts No Rating |
"Can anybody help me out and explain to me how I can make a wall curve in a section view. If the wall I have is curved in plan, how can I make it curve in section also. So basically it would be curving in two different ways. Anyhelp would be much appreciated." Best thing you can do is mass. If I have to make complex wall, go to massing and after click wall by face. This is the quickiest way to do complex objects
----------------------------------- http://tutorials-revit.blogspot.com/ |
Hi, this thread has more than 2 years....
Model Text on Curve Walls |
Wed, Feb 20, 2008 at 1:30:04 PM
curve walls can't host openings.? |
Sun, Feb 5, 2006 at 5:21:03 PM
Logo Placement in Curve Shapes |
Wed, May 2, 2012 at 9:08:20 PM
Lost hatch pattern on massed compound curve wall |
Tue, May 29, 2007 at 10:25:33 AM
Making Curve Ladder Trusses |
Tue, Jan 16, 2018 at 8:21:53 AM
