18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Door Schedule
What i am trying to achieve is to display both the imperial WxHxThickness as well as the Metric conversions in seperate fields. The standard project units are imperial and when i create the new parameters for the metic catatgories they are grayed out in the formating tab/field format to change units. I can always change those fields over to metric but then it's vice versa. how do i display both? the easiest way seemingly is to have a formula with the language of Width = Width in mm, but can't seem to make that work. any suggestions would be appreciated.
If you create a formula that actually does the math for converting mm in inches and then display it in column. This should work.........
Schedule material mark in door schedule - Revit 2014 |
Fri, Jan 19, 2018 at 2:57:03 PM
Door Schedule |
Fri, Aug 17, 2012 at 7:07:50 AM
Customized Door Schedule Needs Help |
Thu, Aug 25, 2011 at 5:53:09 PM
Trying to Schedule a door that lives in a Window Family |
Thu, Jan 16, 2014 at 12:07:10 PM
Manipulating the door schedule |
Wed, Jun 26, 2013 at 10:35:33 PM
11
