11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> view range on new created familiy
Thu, Apr 20, 2006 at 7:48:19 AM | view range on new created familiy
Will9000
4 Stars: 5 Votes
Hi, I have created a new door family, however when i load it into my project the view cut plane does not alter, it appears as if it is cutting through the head and does not show the glazing, i have tried to alter the view cut plane but no matter what figures i use it still does not seem to change, i have also tried creating a new view range around the door and that does not work either, Can anybody help me on this please Many Thanks Will
Thu, Apr 20, 2006 at 5:53:35 PM | RE: view range on new created familiy
eldados
eldados Avatar
4.5 Stars: 8 Votes
you will need to go back to your family and edit the visibility of your components, i.e how it looks when cut or when in plan. click on a component and you should see a visibility button on top somewhere...
Integrator
KarelCAD
Fri, Apr 21, 2006 at 3:53:46 AM | RE: view range on new created familiy
Will9000
4 Stars: 5 Votes
thanks works a treat
component above view range not showing up in plan
Thu, Oct 30, 2008 at 4:27:11 PM
view range
Fri, Sep 7, 2007 at 2:28:04 AM
View Range
Tue, Aug 28, 2007 at 9:52:27 AM
View Range for Revit Link
Thu, Nov 12, 2015 at 7:10:18 AM
low wall not displaying correctly with view range
Fri, Aug 3, 2012 at 4:35:37 PM
Page generation time: 0.9449
