Forums >> Revit Building >> Technical Support >> text width factor for dimensions
Thu, Apr 20, 2006 at 7:30:49 AM | text width factor for dimensions
megmcb
I am looking for a way to change the width factor in the dimensions, there is a section in the properties for almost everything else but that.. is there something I am missing|?
Thu, Apr 20, 2006 at 7:44:21 AM | RE: text width factor for dimensions
reviteer
1 Stars: 1 Votes
I think that text width factor was added in version 8.0, if I remember properly. Check to see if you have anything listed in the help regarding this, or search on AUGI for it. If you aren't finding it, its likely that it was introduced in a subsequent version...
Can you adjust the text width for dimensions?
Thu, Oct 27, 2005 at 5:20:00 PM
Text Box Width Factor Masking Error
Wed, Mar 18, 2015 at 2:33:50 PM
Model Text Width Factor??
Tue, Feb 17, 2009 at 2:10:48 PM
Text width for dimensions...
Tue, Aug 7, 2007 at 7:55:42 AM
Width factor as a parameter
Thu, Oct 30, 2014 at 7:23:29 AM
Page generation time: 0.3754
