Forums >> Community >> The Studio >> Changing line weights to hatching?
Wed, Apr 19, 2006 at 11:21:16 PM | Changing line weights to hatching?
unicorn
How do you change line weight or style in hatching? I have a tiled wall which is hatched with a surface pattern. The line weight of this is very feint, so when I photocopy the drawings the hatching line weight is barely visible.
Wed, Apr 26, 2006 at 7:14:34 PM | RE: Changing line weights to hatching?
eldados
eldados Avatar
4.5 Stars: 8 Votes
clock on your field region---> properties---> edit/new you should see line weight and colour HTH
Integrator
KarelCAD
Wed, Apr 26, 2006 at 10:44:00 PM | RE: Changing line weights to hatching?
unicorn
ofcourse!
changing line weights of hatch patterens
Sun, Dec 11, 2005 at 8:01:22 PM
Changing line weights in a single drawing?
Thu, Apr 8, 2010 at 9:01:02 PM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
Any ideas on modifiying lineweights
Tue, Nov 13, 2007 at 7:59:39 AM
Page generation time: 1.8233
