Forums >> Revit Building >> Technical Support >> Crashing While Converting to a PDF
Wed, Apr 19, 2006 at 4:26:58 PM | Crashing While Converting to a PDF
freestyle250
While trying to convert a sections sheet into a PDF, it hits 60% and freezes. It even crashed the whole program a couple of times. We tried it on 3 different computers in 8.1 but still get the same result. We turned off all planting in the visibility/graphics, and tried it with several different fill patterns to try and simplify the drawing, but still nothing is working. Does anyone have any good ideas on what is going on.
Wed, Apr 19, 2006 at 5:44:28 PM | RE: Crashing While Converting to a PDF
TomDorner
4.5 Stars: 25 Votes
What PDF writer are you using? I have Acrobat 6.0 Professional, but I find that PDF995 does a better faster more complete job. You may want to experiment with it. www.pdf995.com Tom
Thu, Apr 20, 2006 at 10:40:42 AM | RE: Crashing While Converting to a PDF
freestyle250
We run 6.0 as well. Ill give it a try, thanks for the help
Fri, Apr 21, 2006 at 2:09:31 AM | RE: Crashing While Converting to a PDF
meelio
2 Stars: 3 Votes
Another program I use with no dramas is "cutePDF". (It's also free!)
Wed, Jan 5, 2022 at 9:17:01 AM | Crashing While Converting to a PDF
hanbyjm
 I just had this problem and mine turned out to be too many detail items on the sheet.  My boss wanted a quick roof framing plan sketched out to give to the structural engineer.  I used filled regions for the column locations and detail lines for the joist locations.  When going to print, it would freeze up and crash.  When I did finally get a pdf, it was 10,000 KB in size.  I then replaced the regions and lines with model elements and it printed just fine and the pdf file size dropped to 221 KB.  Valuable lesson - use model elements over detail items no matter what.  Smile  Hope this helps someone else.
Print to PDF crashing
Tue, Apr 6, 2010 at 3:55:55 PM
converting files
Wed, Aug 24, 2016 at 9:55:18 AM
converting a revit file into PDF
Fri, Apr 7, 2006 at 2:18:16 PM
Ceiling Tags Crashing Program
Sat, Dec 15, 2007 at 3:03:16 PM
revit crashing
Mon, Jan 23, 2006 at 2:28:30 PM
Page generation time: 0.2688
