Forums >> Revit Building >> Technical Support >> Using standardized detail sheets
Mon, Apr 17, 2006 at 6:25:27 PM | Using standardized detail sheets
JBorst
I've got several small projects that are very similar and I'd like to use the same sheets of details in each of them. The details I am using are old AutoCAD details I've imported into drafting views. I'd like to not have to copy all the linework out of each drafting view into a new drafting view in the next project. Is there a way to copy sheets from one project to another and have the views carry over? If that doesn't work, can I somehow copy all the drafting views from one project to another? Doing it the long way on all of these might just kill me!
Tue, Apr 18, 2006 at 1:23:14 AM | RE: Using standardized detail sheets
Steve_Stafford
5 Stars: 2 Votes
Revit Building 9
Tue, Apr 18, 2006 at 8:05:24 AM | RE: Using standardized detail sheets
bolandereric
Make a Template and put them in once then every time that you need those details open the templete and their they are. Another way that I have found that works is import them in to revit then export them back to the same file. Next time you pull them in from that file they will have all the changes made to them. The easiet way is probably the template.
Tue, Apr 18, 2006 at 8:43:19 AM | RE: Using standardized detail sheets
lpromana
4 Stars: 2 Votes
Revit 9 will allow you to establish a detail library to reuse what ever details you need
Typical Detail sheets on my first revit project
Mon, Feb 8, 2010 at 9:22:07 AM
Can I have one detail on 2 sheets?
Tue, Feb 15, 2011 at 10:12:11 AM
guide grids on sheets revit 2013
Mon, Aug 26, 2013 at 4:11:38 PM
My Section Detail and Numbers will not display on sheets. Can anyone tell me why
Fri, May 21, 2010 at 5:09:18 PM
Dummy Callout for 2017
Thu, Oct 4, 2018 at 8:48:19 AM
Page generation time: 1.3235
