Forums >> Revit Building >> Technical Support >> gates
Wed, Jul 28, 2004 at 11:45:05 PM | gates
renee
Has anyone made gates in railings? Is there an easier way than using a general model and drawing the railings around it?
Thu, Jul 29, 2004 at 9:15:55 AM | RE: gates
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I guess you could make the gate as a separate railing type...depending on how the gate is shaped...
Hiroshi Jacobs
Thu, Jul 29, 2004 at 6:12:30 PM | RE: gates
renee
But then I couldn't show a the swing of the gate...
Fri, Jul 30, 2004 at 12:11:44 AM | RE: gates
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
We've typicall shown the gate in a section of wall to the exact size of the gate. If the gate is 1400mm high and 820 wide make your wall this size to match and place the gate in the wall. You will have to have atleast 1mm or (1/32" depending on where your from) of wall showing either at the bottom or sides so revit doesn't get confused. Cheers, Chris Price.
Fri, Jul 30, 2004 at 9:18:55 AM | RE: gates
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
so you would make the gate as a door? I think that makes a lot of sense.
Hiroshi Jacobs
Sun, Aug 1, 2004 at 5:44:14 PM | RE: gates
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You got it.
Sun, Aug 1, 2004 at 10:11:49 PM | RE: gates
renee
Thanks, Chris!
fence gates
Fri, Aug 3, 2007 at 11:18:48 AM
Adding gates in Revit??
Wed, Oct 8, 2008 at 3:44:36 PM
What are ya'll plans?
Fri, Nov 12, 2010 at 11:26:51 PM
Process Wquipment
Fri, Aug 30, 2013 at 2:24:48 PM
Circular Tag Links Possible?
Mon, Oct 22, 2012 at 4:05:36 PM
Page generation time: 0.0136
