Forums >> Revit Building >> Technical Support >> Curtain wall: Change the glass colour?
Sun, Apr 16, 2006 at 4:13:50 PM | Curtain wall: Change the glass colour?
mmg009
Hi, I know this sounds like a newbie question(because I am one), but how do I change the glass in a curtain wall? I know how to change the material of a regular wall, but I tried clicking the "paint" button then selecting the curtain wall and I can't select it. I want to change the glass to the dark red tinted glass in "materials". There must be a way, can somebody help me out?
Sun, Apr 16, 2006 at 7:13:52 PM | RE: Curtain wall: Change the glass colour?
coreed
coreed Avatar
4 Stars: 16 Votes
1. you have to use the tab key and tab until you get the system panel selected 2. click properties button in the option bar 3. click edit/new 4. under Materials and Finishes click on the field for Glass 5. click the down-arrow to the right of it 6. on the Left side select Glazing: Curtain Wall Glazing 7. On the Right side under Shading if there is a check in the Update when AccuRender selection occurs and you set a color under the color option, it will change the color of the glass in your curtain wall there may be another method but at the monment i am not aware of it. i am a newbie too. Post edited on 2006-04-16 19:18:08 Post edited on 2006-04-16 19:18:24 Post edited on 2006-04-16 19:23:15
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Aug 27, 2010 at 9:52:49 AM | Curtain wall: Change the glass colour?
Thread Post Kudo! #3
allisonkapler
I figured out how to change the color of the 'glass' for the whole project, but is there a way to change each section of curtain wall to its own color? We are looking for a 'MUSAC' type look, and need consective panels to be different colors. any suggestions?
Fri, Aug 27, 2010 at 9:55:36 AM | Curtain wall: Change the glass colour?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Just make different materials and then apply those materials to the different panel types?
Fri, Aug 27, 2010 at 9:58:39 AM | Curtain wall: Change the glass colour?
4 Stars: 205 Votes
You need to create/duplicate the "Glazed" in several different panels with different colours/materials, then you can assign each panel in your curtain wall to the respective Glazed you want... make sense to you?
Fri, Aug 27, 2010 at 10:03:35 AM | Curtain wall: Change the glass colour?
allisonkapler
I know how to create the different colors of glazing as materials but I dont see where I can change it for each particular section of curtain wall.
Fri, Aug 27, 2010 at 10:09:08 AM | Curtain wall: Change the glass colour?
allisonkapler
Got it! Just had to tab through the system to select only the glass!
Thanks again guys!
Fri, Aug 27, 2010 at 10:13:57 AM | Curtain wall: Change the glass colour?
4 Stars: 205 Votes
Alison, why didn't you read what Coreed said: "1. you have to use the tab key and tab until you get the system panel selected ..."  Winking
how to change one 1 curtain wall material
Fri, Sep 5, 2014 at 4:06:44 PM
How to change glass wall to a frosted design?
Wed, Dec 15, 2010 at 5:52:33 PM
Curtain Wall - Glass and Mullion Detail
Tue, Oct 2, 2007 at 4:19:30 PM
Graphic Override and Curtain Walls
Tue, Mar 3, 2009 at 7:26:02 AM
11
Curtain Wall Window Material
Wed, Dec 15, 2021 at 2:04:35 PM
Page generation time: 1.1259
