Forums >> Community >> The Studio >> Site Plans and Topography.............
Sat, Apr 15, 2006 at 9:52:30 PM | Site Plans and Topography.............
dbaptiste
I am trying to build 3D topology using 8.1. I have imported topographic maps from a client and I am trying to trace the contour lines with the point topography tool. No Luck!!! When I "finish" the tool connects points that are on the outer most perimeter. I thought it had something to do with the triangulation option in the visibility and graphics menu. I am totally stumped. How can I reproduce the topology map in Revit, exactly? I need a little advice on this, my project is due in four days.
Sun, Apr 16, 2006 at 8:33:41 AM | RE: Site Plans and Topography.............
latemore
latemore Avatar
3 Stars: 2 Votes
all the experts on this forum keep reminding us newbies to put points on the edge of where you want the topography to finish. maybe do that? also, watch your elevation, at each point. make sure it is as per the contour level. otherwise, it should be working. maybe others can help here.
Sun, Apr 16, 2006 at 1:57:00 PM | RE: Site Plans and Topography.............
rchoutka
1 Stars: 1 Votes
I did the exact thing you are describing, quite successfully. Start from one end of the site, run all the points of ONE (elevation) contour at a time, from one side to the other. If underlay becomes obscured, you can switch to WIREFRAME mode.
site plans and buildings plans
Tue, Apr 17, 2012 at 8:40:07 AM
Site Plans
Wed, Jun 17, 2009 at 7:32:59 AM
Importing site plan to do a 3D topography
Sun, Jan 29, 2006 at 11:53:50 PM
Giving topography thickness when rendering
Thu, Jan 22, 2009 at 9:42:06 AM
Project level vs. site topography RAC 2008
Tue, Jan 29, 2008 at 2:54:56 PM
Page generation time: 0.2937
