Forums >> Revit Building >> Technical Support >> Scaling downloaded hatch patterns
Fri, Apr 14, 2006 at 3:18:51 PM | Scaling downloaded hatch patterns
freestyle250
I just downloaded a couple of ledgestone hatch patterns from the site and was wondering how do I get them to the necessary scale in my drawing. it is n such a small scale that it just shows up as a solid black wall.
Fri, Apr 14, 2006 at 3:57:41 PM | RE: Scaling downloaded hatch patterns
arccodex1
3 Stars: 1 Votes
After you import the custom pattern file you'll notice the Import Scale is greyed out so you have to HIGHLIGHT the pattern name. Then you can change the scale.
Mon, Apr 17, 2006 at 2:29:30 PM | RE: Scaling downloaded hatch patterns
freestyle250
Thats what I thought it should have done, but even after the custom hatch name is selected, the scale remains greyed out at 1/2" I got the pattern off this website, its one of the ledgestone patterns. Do I need to recreate a pattern from scratch at a bigger scale? There has to be an easier way.
Mon, Apr 17, 2006 at 4:56:55 PM | RE: Scaling downloaded hatch patterns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
After selecting which hatch pattern you wish to import, Pick in its name field... Now the scale field becomes active...
Mon, Apr 17, 2006 at 5:30:52 PM | RE: Scaling downloaded hatch patterns
freestyle250
Okay, I figured out what i was doing wrong. I had imported the pattern and already applied to the wall. I then went back in and tried to change the scale of it not realizing that i have to change the import scale DURING the import process, it would not let me do so afterwards. But were good to go now, thanks for the help.
Scaling Hatch patterns
Tue, Apr 18, 2006 at 11:48:59 PM
How to Import Hatch Patterns
Thu, May 31, 2012 at 1:16:12 PM
How to scale Hatch Patterns already loaded in file?
Tue, Apr 19, 2011 at 3:11:31 PM
Custom Hatch Patterns
Thu, Dec 23, 2004 at 3:00:32 PM
Hiding Hatch Patterns [ 1 2 ]
Sat, Aug 29, 2009 at 8:12:25 AM
15
Page generation time: 0.1189
