Forums >> Revit Building >> Technical Support >> Drawing key stones on the edge of a building
Fri, Apr 14, 2006 at 8:45:38 AM | Drawing key stones on the edge of a building
p111evs
Does anybody know how to draw keystones that are fixed to the corner/edge of buildings??
Fri, Apr 14, 2006 at 9:38:26 AM | RE: Drawing key stones on the edge of a building
Dgodfrey
4 Stars: 4 Votes
If you are referring to Quoins, i use solid extrusions and copy them up the corners. they are not wall hosted so they can 'float' if you don't double check the alignments from both viewing angles. Frieze boards i use solid sweeps and band boards i use wall sweeps similar to corner boards. Keys are face hosted components. see attached for a variety of these.
Fri, Apr 14, 2006 at 9:46:45 AM | RE: Drawing key stones on the edge of a building
Dgodfrey
4 Stars: 4 Votes
The dwf doesn't seem to work. here's a jpeg
Fri, Apr 14, 2006 at 9:47:06 AM | RE: Drawing key stones on the edge of a building
rkitect
rkitect Avatar
4 Stars: 29 Votes
Probably the best way would be to make a column with the Quoins that you can place at any corner. In this example every bump out at the corners is a column with the materials, sweep and everything already included int he column family. If the attached family doesn't work, send me an email addy and I'll send you the column .rfa for you to play with. Example: http://gibsonhouse.dyndns.org/famfoto/main.php?g2_view=core%3ADownloadItem&g2_itemId=350
Cannot choose edge of a pad in Revit 2010
Sun, Feb 21, 2010 at 5:16:33 AM
Loading coping stones into the model
Fri, Feb 12, 2010 at 6:17:14 AM
Unit Plan / Key Plan
Mon, Mar 20, 2006 at 4:41:24 PM
RC upstand on the edge of an RC slab
Thu, Jul 14, 2011 at 11:04:56 AM
Revit 2010 Slab Edge Trouble
Mon, Feb 15, 2010 at 8:54:39 AM
Page generation time: 3.2412
