Forums >> Revit Building >> Technical Support >> RevitCity Downloads Not Visible in New Works
Sun, Oct 16, 2016 at 10:03:26 PM | RevitCity Downloads Not Visible in New Works
alexandrabarlow
I've downloaded some pieces of furniture from RevitCity for a university assignment, and when I go to place them into my model, they will only show up in my existing floor plan (phase: existing conditions).
I need them to be placed in my proposed floor plan (phase: new works) but it won't place there/isn't visible.
I'm new to revit and need as much help as I can get for this assignment! Any tips or info as to why the furniture isn't placing would be much appreciated!!!
Mon, Oct 17, 2016 at 7:37:16 AM | RevitCity Downloads Not Visible in New Works
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Can you select the objects and in properties change their phase created parameter to suit your needs?
Mon, Oct 17, 2016 at 7:52:31 AM | RevitCity Downloads Not Visible in New Works
Elnazer2
4 Stars: 5 Votes
If you are not able to select these families you will need to change the phase and phase filter in the view properties to show all first then you select the families you wanna assign to a different phase and change them . and finally set your phase filter to the intended phase.
Edited on: Mon, Oct 17, 2016 at 7:57:44 AM
RevitCity Downloads via FTP?
Sat, Sep 5, 2009 at 5:50:34 AM
RevitCity Downloads not working
Thu, May 31, 2018 at 2:00:23 PM
Deleting old RevitCity downloads that seem to be "stuck"
Wed, Feb 8, 2012 at 9:33:16 AM
free download database
Tue, Jun 4, 2013 at 7:23:01 AM
Rendering with Imported Items from RevitCity ProblemS!
Fri, Nov 2, 2007 at 12:30:22 PM
Page generation time: 0.9108
