Forums >> Community >> Newbies >> ISSUES
Thu, Oct 13, 2016 at 10:09:16 AM | ISSUES
jcornelius0701
I have two issues with my commercial drawings. 1st I am trying to find framing studs and I guess I am doing something wrong. Where can I find some?? 2nd any suggestions on making some plastic vapor barrier?
Thu, Oct 13, 2016 at 10:34:06 AM | ISSUES
Typically studs are not modeled in architectural model.  We only use stud detail elements in enlarged details.  Some contractors who do multiple houses of the same design might want to do stud layout elevations.   Look at the autodesk site in the add-ins and you can find some add-ins that will add the studs.
Vapor barriers are typically never modeled either since their thickness is less than what Revit has the ability to show.
Thu, Oct 13, 2016 at 10:45:07 AM | ISSUES
jcornelius0701
Thank you I wil check it out.
Sat, Oct 15, 2016 at 3:18:38 AM | ISSUES
Dheena14asian
For vapour barrier : You can add them in edit structure option of a wall inside revit.
But revit will not let you to add any thickness.
Default will be Zero always.
I dont know it will be showed in the detail section or not.
Mirror issues, mouse selection issues
Wed, Dec 10, 2014 at 4:14:28 PM
Having issues uploading to Revit City
Mon, Jun 29, 2015 at 12:22:12 PM
Issues with Light Source in Revit 2013
Wed, Jun 5, 2013 at 2:48:23 PM
Visibility/transparency issues. Not seeing through items in interior elevations
Fri, Nov 14, 2008 at 4:20:05 PM
Export 3d DWG issues
Fri, Jun 28, 2013 at 8:27:02 AM
Page generation time: 0.1848
