Forums >> Revit Building >> Technical Support >> equal joist spacing within a beam system
Thu, Apr 13, 2006 at 4:48:24 PM | equal joist spacing within a beam system
lorifilbec
Is there any way to specify an equal number of joist spacing within a beam system?
Fri, Apr 14, 2006 at 3:51:42 AM | RE: equal joist spacing within a beam system
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes, while in the beam system command click on setting or properties (from memory) you can setup spacing there...
Integrator
KarelCAD
Fri, Apr 14, 2006 at 9:02:12 AM | RE: equal joist spacing within a beam system
lorifilbec
duh...thanks.
beam spacing in beam systems
Mon, Jan 11, 2010 at 6:32:09 PM
BEAM SYSTEM
Wed, Sep 17, 2008 at 8:32:42 PM
Beam System Tag
Fri, Aug 14, 2009 at 3:09:33 AM
Beam system justification
Fri, Jan 27, 2012 at 3:47:56 PM
Custom Beam System Tag
Wed, Jun 5, 2013 at 6:03:46 PM
Page generation time: 0.1801
