Forums >> Revit Building >> Technical Support >> Visualization problems with Revit 2017
Fri, Oct 7, 2016 at 12:14:32 PM | Visualization problems with Revit 2017
unnbe
Hello everyone!
How to avoid that during panning and zooming the project disappears? I'm trying to find the solution in the graphic options... with no success so far...
Fri, Oct 7, 2016 at 6:13:43 PM | Visualization problems with Revit 2017
unnbe
I solved!
Add the text "OptimizedViewNavigation=0" under the [Graphics] heading in the Revit.ini
The Revit.ini fie can be found in: C:Users/AppData/Roaming/Autodesk/Revit/Autodesk Revit 2017
Revit 2017 Text Displaying Differently - Windows 7 & 10
Wed, May 17, 2017 at 8:22:58 AM
Revit 2012 to Revit 2016 - Removing Ghost Surfaces Visualization Effect
Thu, Mar 31, 2016 at 10:00:40 AM
Plugin for online visualization
Thu, Feb 21, 2019 at 4:19:49 PM
The Site Designer add in for Revit 2017.
Mon, Feb 20, 2017 at 7:27:25 AM
Artlantis 6.5 for Revit has arrived!
Wed, Feb 1, 2017 at 10:48:31 AM
Page generation time: 4.2401
