Forums >> Revit Systems >> Technical Support >> Auto Sheet Number Extraction while Creating a PDF.
Fri, Oct 7, 2016 at 10:33:42 AM | Auto Sheet Number Extraction while Creating a PDF.
Pikachu123
Is there an option that can be set while creating a pdf, to have the name for a pdf adopt the "Sheet Number" parameter, to save a little time with manually typing the sheet number over to the pdf name, and chance for operator error?
Fri, Oct 7, 2016 at 3:22:52 PM | Auto Sheet Number Extraction while Creating a PDF.
blue442
blue442 Avatar
It does this already when you are priting more than 1 pdf at a time (Seperate)...
Revit 2015 - I did not rename these:
14-1800 (Wilmington) - Sheet - A2-1 - NORTH TOWER 1ST FLOOR PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-2 - NORTH TOWER 2ND FLOOR PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-3 - NORTH TOWER 3RD FLOOR PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-4 - NORTH TOWER 4TH FLOOR PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-5 - NORTH TOWER 5TH FLOOR PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-6 - NORTH TOWER 6TH FLOOR PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-7 - NORTH TOWER 7TH FLOOR PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-8 - NORTH TOWER 8TH FLOOR PLAN & ROOF PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-9 - NORTH TOWER 9TH & 12TH FLOOR PLANS.pdf
14-1800 (Wilmington) - Sheet - A2-10 - NORTH TOWER ROOF PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-11 - SOUTH TOWER 1ST FLOOR PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-12 - SOUTH TOWER 2ND FLOOR PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-13 - SOUTH TOWER 3RD FLOOR PLAN.pdf
14-1800 (Wilmington) - Sheet - A2-14 - SOUTH TOWER 4TH & 5TH FLOOR PLANS.pdf
14-1800 (Wilmington) - Sheet - A2-15 - SOUTH TOWER 7TH & 8TH FLOOR PLANS.pdf
14-1800 (Wilmington) - Sheet - A2-16 - SOUTH TOWER 13TH FLOOR & ROOF PLANS.pdf
Edited on: Fri, Oct 7, 2016 at 3:23:45 PM
Sat, Oct 8, 2016 at 11:31:43 PM | Auto Sheet Number Extraction while Creating a PDF.
Elnazer2
4 Stars: 5 Votes
i use a software called renamer lite to get the exact name i want , before exporting i set the setting in adobe printer properities to prompt for Adobe PDF Filename .... and this skip the option to rename each sheet before exporting it and then after finishing i use that software to delete everything in the PDF names and leave only the sheet number
Edited on: Sat, Oct 8, 2016 at 11:44:25 PM
Mon, Oct 10, 2016 at 10:01:26 AM | Auto Sheet Number Extraction while Creating a PDF.
Pikachu123
Yea, that is where I am at now. I was just seeing if there was an option or something you could check so you wouldnt have to delete everything around the sheet number, just so I could print off likq 100 spools, and just hold the enter button something. Eh I guess Revit wont let you be that lazy... RATS!.. lol
PDF File Names
Thu, Apr 7, 2011 at 8:37:37 AM
File naming when plotting to PDF
Mon, May 2, 2011 at 11:40:29 AM
Sheet Printing - Name of PDF
Thu, Feb 26, 2015 at 10:07:34 AM
Printing a set as PDF's
Sun, Sep 24, 2006 at 8:56:03 PM
Numerate 'Sheet Number' parameter for match line family
Mon, Apr 28, 2014 at 10:17:51 AM
Page generation time: 0.4452
