Forums >> Revit Structure >> Technical Support >> Trusses - Different Chords & Webs
Thu, Oct 6, 2016 at 9:36:06 AM | Trusses - Different Chords & Webs
gregroberson
gregroberson Avatar
I have been evaluating multiple ways of dealing with a farily large project and numerous different trusses throughout the project.  I have looked into grouping which performs well but I loose alot of functionality in the actual project enviornemnt.  I have looked into building my own complex framing family but loose the scheduleing and tagging abilities I am looking for.
Alas. . . the truss family!  Does everything I want functionality wise, schedule wise, tagging abilities. The only problem (and it is a huge one for my anticipated workflow) is that I can only assign one Structural Framing Type Family for ALL the top chords, ALL the (|)web members, All the (/) web members and ALL the bottom chords.
Ahh, revit awesomely lets me change these elements individually in the modelk after the truss is in place so I can have different sizes.  Unfortunatly this can only be done per instance.  I cannot select the truss type and change them all at once and I cannot select the framing element (select all instances) becasue it really doies "select ALL instances" even on different trusses.
Any thoughts on how to get multiple chord & web types to work in a truss family as type elements or select framing elements included in particular truss types?
Any comments are much appreciated.
Thu, Oct 6, 2016 at 11:40:56 AM | Trusses - Different Chords & Webs
You can have sub-families in your truss family that can be controlled by type.
Thu, Oct 6, 2016 at 7:39:23 PM | Trusses - Different Chords & Webs
gregroberson
gregroberson Avatar
WWHub, I figured you would be the one to reply. . . Can you elaborate a bit? Are you referring to loading a structural framing beam into the truss family or defining sweeps and extrusion in the family. I tried loading structural framing families into the complex framing template and lost functionality. Is a sub-family you are referring to different ( I will search the help...but appreciate your direction). If I can get this to work it will save me hours.
Fri, Oct 7, 2016 at 4:10:44 PM | Trusses - Different Chords & Webs
gregroberson
gregroberson Avatar
I have ben attempting to get something to work the way I was hoping. . . but no luck.
I have tried loading a structural framing famly into the truss template; however, a warning states "Can't create element in this family". Bummer.  I alos, tried creating another truss element and loading it into the truss family and I cannot creat that family because the template is drawn in the Level 1 view.
Any additional thoughts?
Truss webs not mitering
Wed, Dec 14, 2011 at 2:58:59 PM
plywood web floor joists and bottom chords of trusses
Wed, Aug 13, 2008 at 11:39:24 AM
Truss Visibility Toggle
Wed, Jan 16, 2013 at 11:05:36 AM
connections in the structural truss
Thu, Apr 4, 2013 at 10:38:14 AM
truss problem
Wed, May 23, 2012 at 1:02:09 PM
Page generation time: 2.4579
