20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Roof Overhangs
2 Posts No Rating |
I am new to Revit and doing my first project....
I want to demolish a section of roof overhangs to make room for a new addition. I've tried editing the existing roof and splitting the overhang at the fascia, but can't figure out how to split the overhang from the roof at the line of the wall. Any suggestions?
Thanks in advance,
Uniqueangle
You could use the opening tool in the modelling tab in the new construction phase on the existing roof for the area you require demolished. Or split the roof into two separate roof sketches, if you are having trouble getting them to align, remember you can go into elevation or section and move the roofs up and down directly rather than trying to work out the proper level offsets...
2 Posts No Rating |
Thanks for the help Mr Spot!
why can't i set overhangs? |
Thu, Mar 22, 2007 at 6:40:29 PM
Adding overhangs to roofs. |
Tue, Mar 10, 2009 at 1:43:22 PM
Newbie - Roof trusses and overhangs |
Fri, Jul 29, 2011 at 3:37:15 PM
How to show overhangs as dashed lines on a floor plan |
Wed, May 23, 2007 at 9:23:46 PM
Roof Overhangs, Facias and Soffits |
Wed, Sep 23, 2015 at 2:07:38 PM
