Forums >> Revit Building >> Technical Support >> Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 3:33:38 PM | Want to see Room Tags but not Rooms
fuentesdesign
When navigating my sections, elevations and plans, its extremely annoying that the room itself is selcted when I try to grab other things, however I generally want my room tags to show up in these situationms. Does anyone know how to stop the rooms from showing up while the room tags stay on?
Wed, Oct 5, 2016 at 3:51:02 PM | Want to see Room Tags but not Rooms
The rooms don't show up until you select them with either a crossing or window but they have to be there to have the tags.   You can remove them from your selection set after doing your selection.
Wed, Oct 5, 2016 at 11:37:51 PM | Want to see Room Tags but not Rooms
Elnazer2
4 Stars: 5 Votes
you can pin all your rooms and uncheck the selection of pinned elements , but i think its easier just to filter your selection .
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
Rooms & Room Tags
Tue, Nov 17, 2009 at 7:14:52 AM
Room Tags -
Thu, Aug 30, 2018 at 11:26:10 AM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Imported 2D Cad drawings > Rooms and Room tags possible?
Fri, Jul 1, 2011 at 1:07:42 PM
Page generation time: 2.0274
