17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Window from floor above showing on ground floor plan
33 Posts No Rating |
I have a house plan and 3 of the first floor windows are randomly shoing up non the ground floor plan.
I checked the view ranges and everything is fine.
What is strange is that there are probbaly 15 windows on the first floor but only 3 are shoing on the ground floor plan. What is more strange is that if I delete one of these windows and copy another window over to the same place it appears of the ground floor plan again.
Seems like a bug - has anyone come across this?
Sorry - this is not a bug but it is a process error. The problem is how do we find out what you are doing wrong.
- Are you copying your windows around or placing them from the window menu?
- Not in a group?
- Are you placing your windows from the correct plan view for the level they should associate with? (Not just a plan you have renamed)
- Are you messing around with the work plane of your plan view for some other purpose?
- Not all windows are the same. Are your windows controlled with a sill or head height? Show us the window properties of the miss-located window.
Thanks for your response - probelm solved.
I rechecked the drawing and there was a plan view right by the windows that was causing them to show up.
Ground Floor info. appearing on Second Floor |
Thu, Jun 9, 2016 at 2:24:40 PM
Faint lines showing from ground floor on first floor |
Sat, Mar 10, 2012 at 4:40:33 PM
First floor slab or ground floor ceiling? |
Fri, Aug 30, 2013 at 7:41:03 AM
Strangest Revit Floor Plan / Level Problem - Not a newbie question |
Wed, Oct 4, 2017 at 1:59:11 PM
Showing windows on the floor plan |
Sat, Feb 28, 2009 at 7:07:23 AM
