Forums >> General Discussion >> Revit Project Management >> Worksharing from 2 different continents
Thu, Sep 29, 2016 at 3:37:40 PM | Worksharing from 2 different continents
hgrimberg
What is the best option for working on the same file from 2 different offices? One of us, does not have an Autodesk subscription.
Thank you
Thu, Sep 29, 2016 at 5:23:51 PM | Worksharing from 2 different continents
If you both have Revit licenses, then there should be no problems with the file.   Your only problem will be file sharing process and the cloud would be the best answer for that.
Thu, Sep 29, 2016 at 6:46:44 PM | Worksharing from 2 different continents
hgrimberg
What if the other party doesn't have a Revit license?
Fri, Sep 30, 2016 at 11:04:24 AM | Worksharing from 2 different continents
Then I would never be involved with them.  I value my own integrety too much to stoop down to that level.
That may also subject your project to litegation from Autodesk.
Creating a mass of globe/ Continents
Mon, Apr 30, 2012 at 12:42:26 PM
Worksharing
Thu, Mar 9, 2006 at 12:29:15 PM
Worksharing
Wed, Aug 20, 2014 at 9:12:07 AM
Worksharing monitor
Wed, May 28, 2008 at 7:48:36 PM
Trying to make a template out of a project that had worksharing enabled
Thu, May 28, 2009 at 2:03:53 PM
Page generation time: 1.2158
