27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Tapered Opening
26 Posts No Rating |
I am working on a job wher the client wants a tapered opening in a wall. For instance the opening may be 5'x5' on the outside but taper back to 4'6"x4'6". Any ideas??
TIA
Is the taper parallel tot he wall itself? If so have you tried using 'Edit Profile' and just sketching the opening in the wall?
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
I think you are talking about a bevel which in plan view i would do with a solid white filled region with a wedge shape. i think a void might be appropriate for the model. if the wall is thick enough, you may just form the "jambs" with another wall set at an angle but the head/sill would not have the bevel.
I used a sweep and that seemed to give the effect I was looking for. Thanks for the suggestions.
Doors / windows in a tapered wall |
Thu, Apr 1, 2010 at 4:20:05 PM
tapered beam |
Wed, Apr 13, 2011 at 4:29:37 PM
Tapered LH Trusses |
Fri, Oct 13, 2006 at 5:05:54 PM
Tapered Beams |
Thu, Nov 4, 2010 at 12:53:49 PM
Tapered Columns |
Mon, Nov 13, 2006 at 11:49:35 AM
