12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Adding Worksets to Templates
105 Posts No Rating |
Revit 2016 and 2017
Revit cannot make a template from a central file, but is there a way to add worksets to a template so when you activate collaboration more than just the three default worksets appear? Is there a way to add more default worksets? Do I just have to manually add the additional office worksets each time we start a new project?
While its true that you can not have worksets in a template, you can do a simple workaround.
- Open a new project with your template
- Enable worksets and add your worksets
- Save the file with a name like Workset Template
- Close the file
Now when you want to start with worksets, simply:
- Open the workset template
- Do a save as with your new file name and using the make this a central file option.
Now you are set.
Obviously this will not help with files that have content before wanting to enable worksets.
Adding a Second Floor to Commercial Templates. |
Thu, Sep 29, 2016 at 9:54:27 AM
adding views to a sheet from another file... |
Tue, Jan 3, 2006 at 10:40:04 AM
Cant Delete one of My worksets...please help |
Thu, Feb 14, 2019 at 1:48:12 PM
13
cannot enable worksets |
Tue, Jan 23, 2018 at 11:00:18 AM
13
Plumbing Switching between worksets |
Tue, Aug 24, 2010 at 2:00:01 PM
