Forums >> Community >> Newbies >> Wall hosted or Surface hosted
Mon, Sep 26, 2016 at 10:22:12 AM | Wall hosted or Surface hosted
FSUarendon
So, I am at a impass, trying to determine which is better for hosting electrical families. Wall hosted or Surface hosted?
Mon, Sep 26, 2016 at 12:53:37 PM | Wall hosted or Surface hosted
marmiketin1
4.5 Stars: 10 Votes
i would use surface hosted as often electrical families are hosted by milwork and other similar type elements
Mon, Sep 26, 2016 at 1:00:09 PM | Wall hosted or Surface hosted
FSUarendon
How would i get the symbol to show up? like for a standard outlet.
Mon, Sep 26, 2016 at 1:21:42 PM | Wall hosted or Surface hosted
marmiketin1
4.5 Stars: 10 Votes
you would draw symbolic lines in plan view of the family
Mon, Sep 26, 2016 at 1:26:49 PM | Wall hosted or Surface hosted
FSUarendon
I'll give it a try thanks!
Mon, Sep 26, 2016 at 2:48:25 PM | Wall hosted or Surface hosted
I think you need to look at the way face based and wall based families work.  If you are doing electrical outlets and switches mounted on walls, wall based families are usually the best because of placement in plan views.  There are times when you will need a face based family for under counter or on other elements instead of walls.  So I prefer two different families.
Mon, Sep 26, 2016 at 2:51:42 PM | Wall hosted or Surface hosted
FSUarendon
We usually use wall based outlets. but occasionally we have to put outlets on wainscots or wall sweeps, wall sweeps etc. so thats where this kinda all came about
Mon, Sep 26, 2016 at 3:40:49 PM | Wall hosted or Surface hosted
I always do wainscots as a thin wall joined to my main wall.   Of course it could also be built into the main wall but that causes problems at crossing walls so the thin wall works best.  I would never use a sweep for a wainscot.
Coverting wall hosted to face hosted familys
Wed, Jun 23, 2010 at 6:11:07 PM
Wall hosted Families
Wed, Feb 11, 2009 at 7:29:20 AM
hosted profile vs. profile
Fri, Jun 5, 2015 at 2:10:31 PM
Wall hosted familes cutting through 2 types of walls
Thu, Oct 27, 2011 at 10:42:15 AM
Wall hosted components in groups............ [ 1 2 ]
Fri, Nov 3, 2006 at 8:09:00 AM
15
Page generation time: 0.5866
