Forums >> Revit Building >> Technical Support >> Family is not of the correct category
Thu, Apr 13, 2006 at 8:32:54 AM | Family is not of the correct category
arch00
I have been getting this message "family is not of the correct category" on a lot of stuff I have been downloading. Please help. Thanx
Thu, Apr 13, 2006 at 11:33:21 AM | RE: Family is not of the correct category
wcrane
The best example i can think of is: Trying to insert a door using the component command. Im not saying this is what you are doing but its similar. If you download a chair, that should be inserted using the Component tool. If you download a door, that should be inserted using the Door tool.
Thu, Apr 13, 2006 at 1:06:25 PM | RE: Family is not of the correct category
arch00
Thanks, was inserting using the wrong tool.
The family is not the correct category
Tue, Sep 12, 2006 at 8:39:41 PM
family is not of the correct category?
Tue, Aug 23, 2005 at 10:29:45 AM
The family is not of the correct category
Sat, Feb 19, 2011 at 5:49:59 PM
Revit 2012 The family is not of the correct category problem
Mon, Mar 19, 2012 at 8:12:03 AM
Baluster category/sub category
Tue, Nov 19, 2013 at 9:43:56 PM
Page generation time: 0.9181
